Tuning Interface Options
WinOLS Mastery: Map Identification & Editing
Relevant Module: WinOLS Tuning Basics > Hardware and Software Requirements
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
I’m new to tuning and have zero experience…I have an 06 WRX, 06 Evo 9, and an 02 GMC 6.0 truck…most likely I will be seeing the older cars but I will be practicing on my cars. I need help choosing an interface that will work for older vehicles such as: Mitsubishi, Subaru, Toyota, Nissan, Chevy, Fords, Kia. Any help and guidance will be very much appreciated.
I've not seen the WinOLS course yet myself so my apologies if this isn't exactly what you're after, but Tactrix has a cable that connects to the Subaru and Mitsu you mentioned and they offer the flash connectors required.
Thankyou, MikeMcGinnis…I will look into that
Hi JPVifixit,
besides Tactrix you can also look into Scanmatik SM2 PRO. This can be used with many software such as PCMFlash and BitBox. It provides the ability to be used as OBD, Bench and also Boot. I have been using it with Toyota, BMW, and Audi. I believe there is more module options which can cover you needs. try to look into it.
buy a tactrix and use ecuflash for subaru and mitsu , and if you need for other brand use bitbox...
you can use winols for this brand but IMHO is not the easiest and best way
