AFR
Practical Reflash Tuning
Hello,Is it normal that my AFRs has to changes whenever I increase my turbo boost such that I have to revisit my all VE table?
If you're increasing your boost levels you will be hitting areas of the fuel map that may not have been tuned so they will need re-tuning.
This is so long as your injectors are big enough and your fuel system is up to the task of the increased boost levels
