aftermarket o2
Practical Reflash Tuning
how did you get the aftermarket wideband to show up on the log
Hey Chris, I get asked about this a lot so i think we might make a short video in the near future. In my case I'm using an Innovate wideband meter. There is a serial output plug on the side of the meter and I'm using an innovate cable from this which terminates in a DB9 serial plug. From here I use a serial to USB adaptor and connect to my laptop so it's completely outside of the HP Tuners interface. Once you have the wideband connected to the laptop you can select the wideband from the serial input options and just add it into the PID list.
would like a fallow up using the lm-2 with hp tuners mpvi2.i cant get it to work.i add the lm-2 eq and statues. but it disappears when i start recording the log.
