can't see wideband in chart vs time
Practical Reflash Tuning
I got a MPVI3 +pro link and LC-2 wideband
I connected my wideband in input 1 (red), used the innovate software to zero my ground.
(set 0.50v at lambda: 0.5 and 0.50v at lambda: 1.5 =reading of 0.53v in channel.
I set 4.50v at lambda: 0.5 and 4.50v at lambda: 1.5 =reading of 4.59v in channel)
Credit: at 20:50 https://www.hpacademy.com/previous-w...o-vcm-scanner/with excel I found the formula (X/3.9016777)+0.3695=lambda X=volt
NOW HERE THE ISSUE
I see my lambda reading in "Channels" on left side but and can't get a reading in "Chart vs. Time"
99 chevy c3500 7.4vortec (454)
Yanick,
To use this channel in the graph area, right click on and edit the graph channel.
To use this channel in the chart vs. time area, right click the strip chart, and add your new channel, or replace an existing channel with your new one.
I try to add a channel but they don't read anything in Chart vs. Time. If you look at MPVI2.1 (V) I don't event see the voltage of my wb.
When you create the channel, HP Tuners usually asks is you want to use the generic name "ie. Lambda or EQ Ratio", say yes to this, and the generic named will probably be used in the histograms. Alternately, edit the histogram settings, to use your channel "MPVI2.1->Innovate - LC-2"
ok thank you, David I will try that this week end. I keep you up dated
Thank you everyone, I figured out.
the air fuel ratio for my wb don't read anything, until I used equivalence ratio. But now the issue was my commanded is only in AFR.
I used math - user -to convert commanded AFR to lambda
-for the MAF calibration formula
