ECU Communication
Practical Reflash Tuning
Gday Andre, I have a 2004 BA falcon XR8,with a boss 260 . The ecu has been previously flashed tuned using an SCT X4 tuner. Given that the installed tune files are encrypted will the HP tuner software be able to read the ecu and allow data logging and adjustments to be made. Cheers Dave
Hello Dave it will need to be turned to a stock map before tuning there is a possiblity that a lot of tables will be missing if you try it like it is now, also you will need to unlock the ecu before it can be tuned at all
ive just had this happen to me
regards ross
I had a feeling that may be the case, thanks Ross. Regards Dave
