Ends in 6 hours
Hello,
I tried to configure the table as explained but it does not work.
When i connect the scanner on the vehicule everything works except my EQ error table
I also copy the labels in the column and paste it in the table but I can not have the same numbers .... for example 1500 Hz become 1.5
The car is a 2010 SS Camaro Chevrolet
Thank you
In order to log EQ Err you need to make sure that you're logging the wideband AFR and that it is in units of lambda. If you're logging in units of AFR then you would want to select AFR Err instead of EQ Err.
Text
