How to get AFR data into HP Tuners scanner software
Practical Reflash Tuning
In the practical reflash tuning there are examples using LS1 engines and HPTuners software. How is AFR wideband data being accessed and being displayed on the scanner? I only know of the innovate device AFR Gauge/O2 sensor , is there any alternative as I have access to a Mainline Hub dyno which has AFR probe as well as OBD II interface so seems like a duplication to buy the innovate product.
If you want to see and log the data in the VCM Scanner, sometimes you can use the OEM O2 sensor if it's a wideband. If not, you will need to buy the Pro Link and the Pro feature set to use an external controller like the Innovate or AEM.
