innovate lm2 afr wideband
Practical Reflash Tuning
hey guys , how are you all ,
For the hp tuners VCM suit , MPVI pro , i have connected the wide band ( innovate lm2 ) to the mpvi pro , and configured the lm2 in the scanner , and also in the chart , but it is giving in stoicho-meteric AFR and not in Lambda , how can i change it to lambda ???
thanks and regards to all
Whenn you configure the input you have the option to select the wideband to read as air fuel ratio which will result in AFR values being displayed, or Equivalence ratio, which will display lambda values. You can just choose the alternative option when you're configuring the input.
hey Andre , how are you ?
thank you for the info , .
can you make a webinar , how to tune in STFT ? just for the info ?
thanks again , and best regards .
and if you can make a course we can buy , for the haltech , same as the link software course . and motec software course .
thank you
hi andre , can you show us , how to tune the hp tuners , with the STFT ? some times i can not stick a wide band with the exhaust if i am road tuning ,
thanks
