MAF rescale
Practical Reflash Tuning
Hi i have same model subaru and completely stock am i still supposed to dial in the load compensations and MAF this way or its cause this example had a larger turbo?
Follow the process used in the worked example. the only time you would vary from this process is if you've fixed the issues with the fuel system.
