MAF scaling beyond 4k rpm on fa20dit WRX
Practical Reflash Tuning
I've managed to successfuly scale MAF sensor on 2018 WRX with COBB guide using SubaruEdit (EcuFlash) but only in range up to almost 4 volts as after open loop kicks in - there's no correction logged. Can you help me understand how to turn on closed loop properly for fa20dit wrx with SubaruEdit?
I found 2 values which I suspect might do something
1 closed/open loop min load (screenshot attached)
2 A/F learning #1 breakpoint (which is set to 4800rpm, is this what I look for?)
Found info in previous lecture, will try to find same tables described for COBB in subaruedit
