Open loop fueling table not showing up
Practical Reflash Tuning
Hello,
I have a 2011 Subaru STI that I'm connecting to through ECU flash. I was able to connect to my car just fine and it seems as though i have the correct definitions as i got no errors but after just checking through the tables i saw that my main primary open loop table was not there. I was curious if anybody else has had this issue and its something with the definition or if its just with my car. any info is appreciated i have not found much in my searches so far.
Thanks
I suspect this could just be the way the tables have been defined. You've got 5 open loop fuel tables and you'll need to make a change to find out which table is being referenced. you can discount the failsafe tables as these are essentially for limp home conditions. So I'd make a reasonable change to one of the other three tables, test, and see if that has changed the actual fuelling. If not, try the remaining tables. Often 'll make the same magnitude change, or even set all three tables to the same targets as in some instances it may not be clear how/when the ECU will use each.
