Openport 2.0 Disconnecting while logging
Practical Reflash Tuning
Hello guys,
Has anybody had an issue while trying to log Evoscan on an Openport 2.0 Tactrix Cable. It starts logging but after a couple of seconds it disconnects and reconnects.
This happened to me trying to log an Evo 6.5 TME.
Hello i found this on a forum it may help
After 3 days I got it working and not disconnecting at all this is what I did if it can help someone with the problem I had.baudrate from 15625 I changed it to 14400 logged for a few seconds and changed it back to 15625. I removed normal RPM from EvoScan and put 2byte RPM and 2byte load it seamed to cure everything. one more thing normally open port 2.0 did not work good and disconnects now it is working better then the 1.3R cable.I have a question to everyone that use's evoscan do you log with normal RPM or 2byte RPM ?
Regards Ross Honnor
