Ram air maps
Practical Reflash Tuning
need to know every thing about these maps please
thanks David i already read the woolich support but the ecuhacking helps more so what do you suggest me to do on the dyno
I think the gist was -- since the bike isn't moving through the air the way the RPM / gear would suggest, you basically set the table to represent the conditions is really sees. I would probably set that whole table to something less than 40 ( I see 32 was recommended) while on the dyno, then set it back when testing on the track. You can tune the fuel for "speed" using that table and not touching the main fuel tables.
