Reflashing an Na engine using ECM alientech to produce burbling exhaust sound
Practical Reflash Tuning
knowing that the injectors in an oem ecu will shutoff in the overrun area ,is adding fuel and retarding the ignition on the overrun area will produce a burbling sound when reflashing an oem ecu ? or do i need to request the overrun map? and how much should i retard the ignition ? should i retard the ignition dramatically ? or retarding just couple off degrees ? i am not looking for an anti-lag style and shooting fire! i am planning to rich and retard 10 degrees the area at 0 to 20% load and 4000 to 6000 Rpm
