Revel Wideband
Practical Reflash Tuning
Hello, still new to tuning, RR and ECUFlash. I have a question regarding the wideband. I purchased a Revel VLS wideband and was wondering if this is something that RomRaider will be able to read. I've notice that there are specific wideband brands in RomRaider already such as AEM and Innovate. Do i need to utilize those instead of the onw I purchased?
Thanks and sorry for the noob question.
Alex,
I've not heard of that wideband, but if it outputs a signal in the 0-5V range and you are datalogging the voltage via an analog input on your engine computer, then you can convert the logged voltage back to lambda or AFR as long as the wideband company provides you with a formula for translation, or a translation table you can turn into a formula. Do you have that info?
