Speed density-based e u
Practical Reflash Tuning
What is the recommended hose diameter for Maf sensor on Link ECU?
Hi Joao, I'm not sure I understand your question? Did you mean MAF or MAP? If you meant MAP then I'd suggest vacuum hose with about a 3-4mm inside diameter.
