uphill full power run
Practical Reflash Tuning
what are the tune considerations if the full power run is done on a uphill road?
Because the load will be higher, the engine will spend more time at a given RPM, usually making it easier to turn from logged data. While driving pay attention to coolant temperature. A longer run can raise the temperatures more than you would see testing on the flats.
