wideband
Practical Reflash Tuning
This guy knows his stuff.
If you are using the non-pro MVPI or the MVPI2 (until the expansion hub is released) this is a way to log WB directly using either A/C Pressure or EGR inputs of the factory ECU. Who knew? https://youtu.be/Ru_2M2uGSKs
In the latest Webinar Andre says hes using his LM2 via CAN into the VCM scanner. How can this be done? Im trying to run my LM2 into VCM with a MVPI2 without modifying the cars by wiring into the AC or anything
