Wideband O2 Sensor Fit
Practical Reflash Tuning
Is the wideband sensor replace the OEM one or is installed next to it in the exhaust pipe?( if it is none portable )
Is there straightfoward wideband O2 sensor plug-and-play replacement?
There are wideband sensors with gauge that got the narrowband output (0-1V). If you are going to replace OEM sensor I'd get one of those with narrowband output and connect to the ECU.
